Gas tank-reserve
RoN of ohio
11-06-2002 19:55:13
I have a 9n and my bro has an 8n. I always open my gas 'shut off valve' all the way. My brother tells me that on his 8n, he opens it only one full turn. Then when working the field and he runs short of fuel, he opens the valve all the way and has enough fuel to get his tractor back to the barn. Similar to a motorcycle shut off valve system. I haven't tried that yet, but come spring when I get her out of the barn, I'll check to see if it works for me.
Gaspump
11-07-2002 05:57:24
 Re: gas tank-reserve in reply to RoN of ohio, 11-06-2002 19:55:13
Instructions on the 8N fuel shutoff valve stamped on the valve wheel say reserve is two full turns open, reserve all the way open. Ditto these instructions in 47 thru 52 owners manuals
norm-wy
11-07-2002 14:14:18
 Re: Re: gas tank-reserve in reply to Gaspump, 11-07-2002 05:57:24
gaspump
Did you mean to say MAIN is two full turns open and reserve is all the way open???
Gaspump
11-07-2002 14:32:51
 Re: Re: Re: gas tank-reserve in reply to norm-wy, 11-07-2002 14:14:18
Yes Norm, that is what I intended to say, thank You!
Fast Ed Ohio
11-06-2002 23:04:00
Early attempt at idiot lights ( its to late now man we got a long walk back to the barn ) .
bg
11-06-2002 21:29:49
Here's a picture of the OEM 9/2N fuel valve. You can see how the reserve function works. The 8N valve is similar in theory, but has a valve which functions on a threaded shaft with a large round turning disc, usually stamped with the instructions. Valves are sometimes replaced, so what you have may not be original or even a reserve-type valve. third party image
RoN of ohio
11-07-2002 08:28:25
 Re: Re: gas tank-reserve in reply to bg, 11-06-2002 21:29:49
Mine must be an 'after market' or 8n valve cause it is a large disk with threads. Haven't taken it out of tank, but would be curious to see if if it has the dual inlets as per your picture. thanks..Ron
chief 83
11-06-2002 20:51:54
He's right on the 8N. I'm not sure about the 9.
chief 83
11-06-2002 20:51:42
