When was the tractor last run? If it's been a while, you probably need to clean the carburetor and fuel filters and add fresh gas. You also need to check the oil and coolant before trying to start. If the oil is black and nasty, it might be advisable to change it. Straight 30 weight is a good choice. An I&T FO-4 manual will provide service information. It may be helpful to enlist the aid of a mechanic or other N-owner to help you. There is a plethora of things that can affect starting, and unless you have a modicum of experience in things mechanical, the explanations can be elusive. Having said all of that, you need 3 things: fuel in the proper quantity spark at the right time air Troubleshooting is a systematic approach to each system in turn. If all the systems are correct the tractor should start. Post some pertinent details, like the year of your tractor, what you've done and specific symptoms and the folks here will be able to help with specific questions as you proceed. You might want to visit John Smith's site for a wealth of good info.
