Will JB Weld work with plastic?
Popster (MD)`
11-10-2002 20:46:51
I was going to use some MarineTex to repair a sonar transducer. Unfortunately, the MarineTex grew legs and left town.
I have some JB Weld. Will it hold on plastic. I lost the package. Need to launch boat in early AM so any replies appreciated.
Thanks
Popster (MD)`
11-11-2002 12:56:01
 Re: Will JB Weld work with plastic? in reply to Popster (MD)`, 11-10-2002 20:46:51
Thanks guys! We routinely epoxy transducers to the inside of the hull so we can shoot through the hull instead of mounting the transducer on the outside of the transome. The JB weld did the job!
Les, TN
11-11-2002 08:03:48
Depends on the plastic. If it's polypropylene, f'git it. That's gotta be welded with heat. Most other plastics will allow JB to stick. It'd be good to rough-up the part a bit with a little sandpaper to texturize the surface an' give it sumpthin ta grab aholt of.
Levi(WA)
11-10-2002 23:10:06
I have fixed several plastic things with a 2 part epoxy, it wasn't JB weld, but it worked VERY well
andy
11-10-2002 21:14:18
Generally epoxies will not work on plastics. The only things that work with plastics are the type of adhesives that melt the base materials and weld the two pieces together. You might have better luck using 3m 5200, and encasing the piece with it.
