1952--8n ring gear problems
help
9n141
11-14-2002 18:42:24
Bought new ring gear installed it in the usual manner, after it cooled (over night), it was still loose. Took it to NH dealer where we bought the ring gear, they pressed the gear off and said they had never seen a fly wheel like it & they could not get it to work. The shop foreman & the mechanic that worked on it are both friends, good mechanics & restore tractors themselves. WE have done several ring gears before we have never seen a flywheel with a grove like this one????? HELP BURT>
9n141
11-15-2002 19:19:58
 Re: 1952--8n ring gear problems - help in reply to 9n141, 11-14-2002 18:42:24
We took it to top notch welder & welded it with mig welder. THANKS for good advise. BURT.
DON TX
11-14-2002 20:45:25
If I understand you right, the ring gear is loose after installed? Try tack weld the gear. If too loose to tack weld, weld a small, short bead around the flywheel in several places and grind down to snug fit and tackweld gear. HTH
DON TX
ZANE
11-14-2002 19:12:12
Looks like you will either have to find another fly wheel or weld the ring gear to the fly wheel in about four places and put it back together.
Did you heat the ring gear to a blug color and drop it on the flywheel or did you have to hammer it on. If it is heated right you don't have to hit it with a hammer at all. If it heated too hot it won't work either. Like red hot.
