Negative or Positeve for 12Volt?
Rad
12-21-2002 09:58:05
I recently had a 12 volt system installed on my 8N. Problem is, I ran the battery down due to something else, had to take it off. Now I want to put it back on the tractor, but don't know if my negative is ground or not?? I appreciate any info.
12 volts is negative . . . Dell (WA)
12-21-2002 10:17:07
 Re: Negative or Positeve for 12Volt? in reply to Rad, 12-21-2002 09:58:05
Rad..... ...your 12 volt alternator's internal solid state devices absolutely DEMAND negative ground battery. Otherwize, you've just demonstrated how fast semi-conductor fuses can smoke..... ..Dell
Dave Smith
12-21-2002 10:13:46
Negative ground. If you connect it backwards you will blow the alternator.
Dave <*)))><
