Give due attention to the usual experts' opinions here, but my experience with the flooding problem is to get a carb rebuilt kit and install it. Or, pay someone with experience to install it for you. I found that rebuilding the carb prevents a lot of problems. There are so many things that could go wrong in a carb, and likely more than one thing at a time. It's worth it to eliminate all those possible problem areas once and for all. It looks like you might have 2 problems at the same time: carb & starter (?). But, if you get the carb rebuilt, you know that that variable is not a factor. To repeat myself, there's just so much to go wrong in the carb. After all, all those elastemeric (rubber) parts and all don't have a very long life. The float (bakelite?) can break down over time, too. You can get gas deposits, etc. That's just my opinion. With both our tractors (and a couple of snowblowers), we just bit the bullet (sorry for the old cliche) and had the carb rebuilt. To us, it seemed to eliminate a lot of starting headaches. Again, heed the experts' advice first. I just wanted to add my experience. Bri
