Jubilee Hydraulics-Thanks Jim Spencer/Zane
Alan
12-28-2002 15:18:48
Fired my Jubilee up today and got the Hydraulics to work pretty well....so I believe that the Back Pressure Valve stuck open was the culprit...Worked well in Postion Control in OK Draft Control and I believe the hiccups are gone too ( I think the check valve steel ball did it)....The only problem left is that in Daft Control with the quadrant all the way up the Lift Arms only come about half way up....Linkage adjustment I guess .....Just wanted to say Thanks guys cause I probably would have started replacing things....$$$$$$.... Alan
