1955 running boards-Jim.UT
9n141
12-29-2002 12:29:37
JIM as promised ser#s-631 #54681 angle boards. 850 #66818 FLAT ??? checked twice. 860 #26584 flat. 960 #38615 flat. 740 #41780 ANGEL???? checked twice. 860 #97348 angle. 850 #23200 flat. NOW what? This confuses previus research. BURT.
Big Mike
12-30-2002 21:31:55
 Re: 1955 running boards-Jim.UT in reply to 9n141, 12-29-2002 12:29:37
Double checked the 850 today and I was wrong they are flat not angled..its ser # 53***...Big Mike
Jim.UT
12-30-2002 09:41:59
I had a feeling something like this would happen. Thanks for doing the "field work" on this. Here's what I found over the weekend:
I thought I should look in my NAA/Hundred series parts book to see if they specified a serial number break on the running board change. What I found was that the flat boards specified for ALL 1955 tractors and angle boards for all others. It looks like maybe any '55 Hundred series with angle boards is an owner upgrade (?).
Here's another question for you. It looks like the radius rod caps on '55 tractors have the "L" shaped peg cast on it. This is used to mount the flat boards. My 850 with the angle boards also has the "L" peg. That's what first got me wondering about the originality of the running boards. Why use radius rod caps with foot board pegs that won't be used? Now my question: on your tractors with the angle boards, do they also have the "L" peg on the radius rod cap?
9n141
12-30-2002 18:42:22
 Re: Re: 1955 running boards-Jim.UT in reply to Jim.UT, 12-30-2002 09:41:59
NO . The angle boards mount behind the radius rods & flat boards mount on the outside, this gives some steering problems, which can be corrected. BURT.
