Manifold removal, impact wrench or hand?
Popster (MD)
12-29-2002 17:49:45
I have the option of using a 1/2" impact wrench, 3/8" impact wrench, or hand powered socket. I have been spraying the nuts for a few days with silikroil.
Any advanage to using an impact over a hand tool?
Thanks.
Popster (MD)
12-29-2002 19:02:50
 Re: Manifold removal, impact wrench or hand? in reply to Popster (MD), 12-29-2002 17:49:45
Thanks Guys,
By hand it is.
raytasch
12-29-2002 18:08:33
Popster, Be very careful with an impact wrench on your manifold studs. They are pretty small to be using an impact wrench. If you do use an impact wrench I suggest you use it on the lowest setting. Sometimes the vibration that the impact wrench sets up will help break the bolt or nut loose; So easy to break the stud or bolt off with an impact wrench. Do be careful.
ray
simonmeridew
12-29-2002 18:04:17
Use the hand sockets. The first move might be to tighten a little bit, then loosen. That should work, even though it looks rusted shut.
TimK
12-30-2002 07:43:28
 Re: Re: Manifold removal, impact wrench or hand? in reply to simonmeridew, 12-29-2002 18:04:17
I would not use any air tools on an old tractor, excluding the wheel lugs, unless I had already removed the nut/bolt before. Breaking a stud or bolt off in one of these oldies will make a believer out of you, trust me !
