Order Ford 8N Parts Online
8n water pump
rick
12-30-2002 05:31:02
i am wondering if anyone had a problem like this? my 8n gets hot when bushhogging but will not overheat when idling? checked radiator for weed matter ,timimg etc. could the water pump impellers be gone? when yu look in radiator i see no water surging?belt is tight so no slipping that i know of. thanks--had a fuel problem in summer ,would run then quit finally found mud dauber nest on top of fuel vent!!just enough to allow one trip around field.thanks again!
IF...............bg
12-30-2002 05:40:04
 Re: 8n water pump in reply to rick, 12-30-2002 05:31:02
...the radiator fins are clean and the timing is correct and the advance mechanism is working properly, and the thermostat is installed and functioning correctly, and there is sufficient coolant, that sorta narrows it down to water pump or radiator. You can flow-test the radiator and you can back-flush the block and water pump(engine cold)before pulling the water pump for rebuild or replacement.
rick
12-30-2002 06:07:04
 Re: Re: 8n water pump in reply to IF...............bg, 12-30-2002 05:40:04
thanks, will do!
