Carbon
Pat
12-19-2000 20:36:22
The head is off and number 3 and 4 cylinders are pretty carboned up. What is the best way to clean some of that carbon out with out wrecking things? Also, what is the best way to scrape that old head gasket off?
tlak
12-21-2000 05:23:03
 Re: Carbon in reply to Pat, 12-19-2000 20:36:22
Dont know if it will help in your situation but when I did a overhaul once I put motor oil in a coffee can and set the piston in it overnite. This worked so well you wiped off the old carbon with a rag.
fast ed ohio
12-19-2000 21:26:58
wire brush wheel on drill. putty knife on gasket. thats the old timer way. things could have changed.
