Sal..... ....that might have been me. My carry-all frame came drilled for 1/2 bolts. (I used 1/2 zink galvanized carrage bolts) While the pre-drilled hole didn't exactly center on each plank, its close enuff. For the back, I used 2X6 X 42", with 1-1/2" air gap. (used a spare 2 bye as a spacer) For the deck or bottom, I used 2X8 X 72" with 1-1/2" air gap except at the corner bend where I used a 2X6. I originally use 2X10 X 42" on the bottom with NO airgap. While it matched the back, most everything I was carrying hung off the sides and slid off or bounced around. I was carrying 8' feeders or 7' fence posts, so 6' bottom really works for me. I haven't had anything fall thru the 1-1/2" airgap. I found an old wire bicycle basket that I fastened to the top of the back to carry small things, including some tightening straps..... ..Dell
