Order Ford 8N Parts Online
Remote Hyd on 8N
Joe
01-12-2003 04:37:24
Will the plate that is made for the 800 series tractors remote hyds (plate under seat) work on my 8N. If not where can I get one.
no . . . Dell (WA)
01-12-2003 08:23:33
 Re: Remote Hyd on 8N in reply to Joe, 01-12-2003 04:37:24
Joe..... ....NO, the remotes hydraulics plate from 800 won't fit because there is no holes for it to fit. And even if'n ya had a machine shop drill and hogg out the cover so ya could mount yer 800 hydraulics remote ports, ya still got a problem, the N's hydraulic system.
Unfortuneately, the N was NOT designed for remote hydraulics like the 800's were. Ford learned the desireablity of remote hydraulics from the complaints of early N owners.
And yeah, there have been some clever N-mechanics that figgered out how to get the internal hydraulics out (remote) by using the little corner pressure test port of the hydraulic pump baseplate and chaining down the 3-point lift arms.
I'm not a strong advocate of the technique because the N's hydraulic pump is a weak sister. Its a 2.85 gpm 1700 psi hydraulic pump, most are lucky to pump 2.5 gpm 1500 psi. Remember, its pressure up and gravity down..... ....Dell
