I continue to troubleshoot my non starting front mount 8N. It started to lack power, carb settings appeared to not work properly, then hard to start, then just a few turns and died, then dead.I've been meaning to go over tractor and do major tune up; looks like the time is now. Motor was rebuilt less than 150 hours ago, compression fine, etc. I would note that the exhaust pipe (new approximately 4 years ago and still plated in most parts) burned through on the seam just below the manifold. I'm guessing this is unrelated to non-starting problem, but I am a newbie. I went through tune up, gave it new copper wires, cap, rotor, .... etc. Got it back together today and have bright white blue sparkies. When I replaced plugs I noted that #1 looked normal light tan, #2 lighter tan, #3 almost white, #4 like new white. Has new screen in tank and tank was drained when screen installed, fuel bowl clean. Carb screens were clean. Fuel runs out of bottom of carb when the drain plug pulled. Gave it a shot of ether in the carb and not even a pop. I'm guessing it has a bad manifold. Just happen to have a replacement from Just 8N ready to go. Any predictions before I pull manifold? I've been squirting the 4 bolts with Silikroil for over a week. Here's hoping! It's too windy and cold to go fishing or oystering, so may as well cut firewood and get the 8N straight! Many thanks.
