Problem need some help
Rick(GA)
01-13-2003 11:52:13
My pinion gear has about half of its teeth and my PTO shaft is dangling. I was backing up when allof a sudden there was this thud and then a gnashing and gnarling sound. I drove it back to the barn as the sould grew louder before the snow hit. Can I still use the lift and put a blade on it? Rick(GA)
Mike S
01-13-2003 17:46:47
 Re: Problem need some help in reply to Rick(GA), 01-13-2003 11:52:13
Hi Rick, where are you in GA?. I didn't know we had any snow. I am in Alpharetta.
bg
01-13-2003 12:55:16
Since you already have it in the barn, it might be smart to go ahead and replace the pinion and inspect the ring gear. I don't know why the PTO would be dangling. I'd bet that if you put a blade on and try to drive it , you'll end up towing it back to the barn.
OH Boy
01-13-2003 12:38:37
Sounds like something thats gonna get worse if you ignore it, in my opinion.
