Order Ford 9N Parts Online
9N/2N Rear Wheel Bearing Removal
OH Boy
01-13-2003 19:49:19
Ok N Guys, I took my (47 2N) rear wheel hubs off, to check the brakes (WHEW what a greasy mess!) and I can see one of the roller bearings is messed up a little bit, needs replaced. Got the bearing retainer collar off by drilling and chiseling. Thought the bearing would slide off at this point - Wrong! It seems to be pressed onto the axle. The FO4 manual says to 'Pull it off with a suitable puller'. Gee thats a great idea, why didn't I think of that?
Can anybody tell me how to rig up a puller to pull that hub and bearing off the axle? It's like 2 feet from the end of the shaft so a regular old gear puller ain't gonna reach.
I'm going to replace the beaings, seals and brake shoes, need to get it all apart so I can clean it all up, repaint, etc.
Thanks in advance, I know one of you guys has already been here.
SteveB(wi)
01-14-2003 20:06:52
 Re: 9N/2N Rear Wheel Bearing Removal in reply to OH Boy, 01-13-2003 19:49:19
I VERY CAREFULLY torched mine off, but a press at a shop is a better alternative.
Dan (Myersville)
01-14-2003 08:08:22
Older RWD car axles responded well to a hydraulic press and a bearing separator. Never done an N axle (still working my way to the rear ;-)
Crispy
01-14-2003 05:46:38
Sorry I can't be of more help. When I did repair my rear brakes, hubs ect. I did not have to replace the bearings, they were alright. I did use the SURE SEALS. Hope someone will give you insight as to replaceing your actual bearing.
Crispy
don b
01-14-2003 11:46:58
 Re: Re: 9N/2N Rear Wheel Bearing Removal in reply to Crispy, 01-14-2003 05:46:38
They had a special puller[about 2' long] for that.I have one you can borrow if you can't get it off. don
