Need help finding gears for PTO Belt Pulley Gearbox
Roland Jackson
01-14-2003 19:36:58
Have a piece of equipment that has the Belt Pulley Gear Box from a 8N Ford. Ford New Holland shows the gears to be discontinued...however...we do have the numbers. Anyone know where I might find replacement gears....new or used? Were there several different brands belt pulleys for the fords. Seems to me that I have seen several different styles in the past. Thanks in advance for your help.
jack nc
01-15-2003 15:20:23
 Re: Need help finding gears for PTO Belt Pulley Gearbox in reply to Roland Jackson, 01-14-2003 19:36:58
keep checking ebay under 8n ford. they have them on there all the time if your are talking about the one that bolts on over pto shaft on rear of tractor. they usually go pretty cheap. hope this helps
Scott(Ks.)
01-15-2003 01:28:46
Some of the older rotary mowers used the same gearbox for the direction change on the mower.
I know that BMB now Rhino did originally.
Capt Jack
01-14-2003 19:58:26
Did you try Just 8N's yet? That would be a good place to start.
Good luck.
