I could offer a long-winded dose of carb theory, but here are a few pointers to get you started. You must pay attention to engine RPM when tuning the carb. If you try to do it by ear like you would tune a carbureted car, you will be fooled by the different RPM ranges that this carb was designed to operate at. The main mixture sytem begins to be effective at about 600 RPM. Most tractors tuned by ear are set to idle above 600 RPM. So you are tuning a mix of the main metering system and the idle jet, unless you use a tachometer and tweak up the throttle linkage and governor to actually allow the 400 RPM idle. Most carbureted cars run almost exclusively off the idle system up to 1000 RPM, so the tractor doesn't tune like you "expect". It is a lot easier to separate out the various effects if you disconnect the link from the governor to the carburetor and substitute a spring to hold the throttle closed. Otherwise the governor can try to compensate for your tuning. The idle screw works in reverse. As you unscrew it, you admit additional air to the fuel being supplied through the idle jet. The tuning range afforded by this design is rather limited, and a common lament is that the mixture starts out too lean already, even with the screw fully closed. Unscrewing the screw can only make the mixture leaner, which won't do anything for you if you were starting out lean. The reproduction Marvel Schebler carbs seem to work like this out of the box, by the way. The idle system draws its fuel through the same flow restrictor as the main metering system. If you close the main metering screw all the way, it cuts off all flow to both systems. I suspect you are running at a relatively fast idle, and that you are running mostly off the main metering system. You can unscrew the idle jet all the way without effect, because of the previously mentioned reverse idle system and limited tuning range, and because the main metering jet is taking up the slack anyway. You can unscrew the main metering jet all the way, without seeming effect, and not run "sloppy rich", due to a combination of the flow restriction in the passage leading to the main nozzle and the limited effectiveness of the venturi at less than 1000 RPM. You should find you have some tuning effect at a 700 RPM idle of turning the main metering nozzle in, prior to it contacting the seat. If you are running slow enough, you may find you can run the idle screw all the way in, and acheive some tuning effect as well. The transition from idle to main jet is one of the weak points of the Marvel Schebler design, even in perfect condition, and I suspect you are trying to tune it right in that range.
