Year based on Serial number
Andrew Stepania
01-17-2003 06:53:26
I thought it was safe to assume I have a 9N based on the Serial number '9N208827'...but I am getting some comments that it is an 8N or a 2N...anybody know why this isn't a 9N...and what then it is...and of course why?
Thanks in advance!!!
Ken N Tx
01-17-2003 11:41:44
 Re: Year based on Serial number in reply to Andrew Stepanian, 01-17-2003 06:53:26
3 speed forward trans= 2N....brakes on left and right= 2N ...1939 to 1941= 9N..1942 to 1947= 2N..1947 to 1952= 8N...Brakes on right, clutch on left= 8N...4 speed trans= 8N...check Smith's link below, great site...
Farmer Tim *8N15513*
01-17-2003 07:43:41
Hi Andrew-
I believe you have a 2N The 2N began production in 1942 with serial number 99003 and ended in 1947 with 296131. Hope this is of some help. Why would someone say it is an 8N with the 9N prefix?
Tim Daley
Barnstormer
01-17-2003 09:33:49
 Re: Re: Year based on Serial number in reply to Farmer Tim *8N15513*, 01-17-2003 07:43:41
Tim, there are so many N's that have had engine swaps that a 8N could have a 9N engine. 30 years ago that was cheaper than a rebuild.
01-18-2003 05:43:20
 Re: Re: Re: Year based on Serial number in reply to Barnstormer, 01-17-2003 09:33:49
Barnstormer-
Yes, your right, I overlooked the obvious. Perhaps other signs like if the trans is three or four speed, rear wheels, air cleaner, generator, etc., would be more of a true indication of it's identity.
Thanks
Tim
Chris(MI)
01-17-2003 07:01:19
Based on your serial # you should have a 1946 2N. All 2N serial #'s begin with 9N. Or you could have another model if the engine has been replaced. Need more info. Check out the link below to find out how to tell.
Chris
