OT Barn Construction
Sal
01-25-2003 17:28:07
Hello,
I have been saving up to build another barn. I finally got to the point where I have enough saved to start planning what I want and maybe build later this year
I know the size I want, but I am not sure on which construction method to go with.
I am thinking of either a pole barn style or going with a poured concrete stem wall and build a post and beam off that or 2x6 stick frame.
My current barn is a big old timber frame that is great. This new one will be 30x40 with a metal roof and heated floor. Going for 12-14'high ceiling inside.
I am leaning towards the 2x6 walls at this time, since they can be insulated well and the building could be utilized for many things down the road.
Any big drawbacks on pole barns, I am thinking insulating them and such won't result in an interior that is as 'finished' looking as regular stick framing.
-Sal
Dave in Iowa
01-27-2003 06:52:54
 Re: OT Barn Construction in reply to Sal, 01-25-2003 17:28:07
Hi Sal,
I built a new building a couple of years ago, with many of the same requirements as you. I chose to go with a 36'x53'Morton building with 12' ceilings primarily because of the insulation package they offered. With 7"6" between main wall beams they are able to put 9" thick bats that have no thermal interuption for nearly 8'across. Then they put 14" of blown-in into the ceiling. I heat the place with in-floor radiant heat (which I installed). In the coldest days of winter hear in Iowa it cost about $30 per month to heat to 68 degrees. I zoned the front half and the back half of the shop seperately. I chose to go for the ribbed metal interior because I like the clean look it offers. One thing the salesman talked me into is using sound absorbing panels on the walls 4' down form the ceiling. They work GREAT! I've been in steel interior building where the echo was so bad it's hard to talk. These panels really work.
I wanted absolute protection from rodents, so I built the building on 2' high concrete knee walls (higher concrete walls where the building is built into a hill). I love having concrete all the way around. Plus, I've found that I can mount some things to the concrete wall without having to drill into the floor and risk damage to the heat tubing. I'll send a photo of my vise stand if your interested.
As far as radiant heat... It's the greatest. I use a 75,000 BTU boiler, but think I could almost heat the place with a residential water heater. If you can sweat copper and run some gas pipe you can install radiant. The key is getting a plumbing house to help you source all the components. And make sure to use a high quality PEX pipe in the floor. I'll post a picture of the heating plant if I get a chance to snap one soon. In a building with high ceilings it's great because you don't have all the heated air at the ceiling. Plus when you open the overhead doors you don't loose all the heat.
One more thing to consider is beefing up the concrete floor a bit. For not much more cost I went for a 7-bag mix (they call it Interstate mix), plus added fibermesh (shredded fiberglass strands) into the mix for strength and crack control. So with the radiant floor system it layers like this: gravel, vapor barrier, 2" rigid foam insulation, 6"x6" weld wire (to tie the PEX tubing to), PEX tubing 1' on center (2' on center is ok also), 1/2" rebar 2' on center, then 4" of beefed up concrete. Good help the person who has to tear it out someday! But with heavy equipment I don't worry about the floor.
Good luck on your project!
Texas2N
01-26-2003 09:54:05
I built a 3-Bay Equipment Shed with Loft from Sheldon Designs. Plan #N-SDHD. The Plan now costs about $45. Look at site www.barnsbarnsbarns.com. I did some modifications like put stairs outside and metal on the lower portion. I built this BY MYSELF and used cheep pressure treated 6-inch poles (instead of the 4x6's they call for. My neighbors claim that in the case of a tornado, they're going into my barn. I spent less than $2500.00 for a 20x30 barn. If you are interested I'll let you have my copy of the plans for FREE.
I'll even give you my insites on how to do this BY YOURSELF.
bg
01-25-2003 22:23:20
You might want to consider SIP's for a totally insulated building. Although the initial cost per panel is a little higher, you save on header material, sheathing and labor. You get the R-value of a 2 x 6 conventionally-framed/insulated wall in a 4" SIP. Panels taller than 8' cost more, but you can stack panels. 3 4'x8' panels could be stacked to give you an 8'x12' section. SIP's have an outer skin of OSB so you don't have to use extra sheathing and can apply siding or finish materials directly. they also have a better fire-rating, since there is no air-space inside the walls. Wiring channels are pre-formed so you can put outlets and switches at any location at the pre-determined height by simply cutting a hole for the box with a Roto-Zip. They also work well between the bays of a timber-frame building.
follow-up
01-27-2003 08:14:52
 Re: Re: OT Barn Construction in reply to bg, 01-25-2003 22:23:20
just talked to my SIP rep. SIPs are now being priced by square foot, so you can buy a 10 or 12'(up to 24')panel at the same cost per foot as an 8'. However, you CAN stack SIPs up to 3 stories. Shear strength is 4x conventional framing.
David - OR
01-26-2003 09:57:43
If you stack SIPs in the manner that bg proposes, they lose their load-bearing properties. The whole reason that they work is the unbroken, continuously supported OSB sheet, forming a "stressed skin panel". The joints needed to accomplish stacking will be much weaker than the OSB skin in panels oriented vertically. Their shear wall performance (already somewhat worse than conventional stud and plywood) is also suspect in this orientation. I would be hesitant to
As an engineered material, SIPs must be installed according to the manufacturer's instructions, and I've not personally seen any instructions supporting "stacked wall panels".
Stacking SIPs seems like a great way to get an economical, high-insulation-value wall, but only for timber frame or post frame infill, and not for a load-bearing wall. In this application, there is a SIP product that might work that has OSB on the outside and drywall on the inside, possibly saving another construction step.
One way to make the most of SIPs for a 12 foot shop wall would be to use a 4 foot "pony wall" of concrete or concrete blocks, and then put a standard 8 foot SIP wall on top of that. The lower wall section has enhanced resistance to fire, water, and mechanical damage, useful properties for a shop or barn. The upper SIP wall retains its desirable structural, economic, and insulative properties.
bg
01-26-2003 13:07:22
 Re: Re: Re: OT Barn Construction in reply to David - OR, 01-26-2003 09:57:43
You can get SIPs in any size that a truck can tote, but you can stack the panels. We built a 1.5 story house with solid sip gable end walls with an 8/12 pitch and three purlins to support the roof panels. I'm not sure I'd agree about the shear factor. I know the racking strength is higher with SIP. Here's a picture of a SIP house with stacked gable wall panels:
third party image
Dave Smith, I hate to seem stupid but
01-27-2003 12:04:20
 Re: Re: Re: Re: OT Barn Construction in reply to bg, 01-26-2003 13:07:22
What is SIP? In the photo it looks like what we call chip board or flake board. It is made of trash wood such as popular that is chipped and glued back together. It works good for deer tree stands if it is painted or covered. Because the 1/4 inch is easy to cary up the tree. When it gets wet it falls apart. When it first came out a friend of mine used it for sub flooring. BIG, BIG mistake within 5 years he had to rip it up and replace it with plywood. It has no rigidity.
Dave <*)))><
bg
01-27-2003 21:53:41
 Re: Re: Re: Re: Re: OT Barn Construction in reply to Dave Smith, I hate to seem stupid but, 01-27-2003 12:04:20
Structural Insulated Panel. It's not flakeboard or chipboard or particle board. It's OSB(oriented strand board) bonded to EPS(expanded polystyrene foam, same as coffee cups) It has SUPERIOR insulating properties, and strength. Construction is simple because ordinary door and windows(under certain length) are not required, and you can dry in a 1200 square foot 1-story house in a day(with a good foreman), using unskilled labor. For more info go to sipweb.com or SIPA website.
PAT
01-25-2003 21:47:59
hello sal , fellow ny'er here, having the same dilemma, I am going to build one too, about the same size as you, I have heard lumber stores like 84 lumber, and wipples by me in norwich has a pretty good deal on the barn kits they sell, I am looking into it, do you have any info sites about the radiant heat flooring, some say it can be done by yourself, others say you need a contractor, I know if you know nothing about nothing hire it out but kinda handy so I think I can handle it,, I cant wait to have it up so next winter the N will be warm, and me to,so I can get back to wood working, see ya have a good one pat
Sal
01-25-2003 23:17:59
 Re: Re: OT Barn Construction in reply to PAT, 01-25-2003 21:47:59
Pat,
I have looked into the radiant floor heating and I don't see any problem in doing it myself. I will have a crew pour the slab though.
Here is a good link to learn about installation.
Here in Syracuse area there are a number of plumbing/heating supply houses that will take your bldg plans and design a radiant system for you at no charge as long as you buy the supplies from them. My neighbor works at one and says it is really simple and from what he has shown me I agree. Also, these places have the installation information from the manufacturer that they will give you...I learned a lot this way.
I like being able to design multiple zones and that there is the ability for snow melt area's in front of doors.
As for kit's on barns, I have not looked at them yet. I am usually short on time for a project this big so I will have the barn built. There are some good barn and garage builders around here and I really like Woodford Brothers a lot...might go with them.
Keep in touch.
-Sal
pat
01-26-2003 07:32:17
 Re: Re: Re: OT Barn Construction in reply to Sal, 01-25-2003 23:17:59
thanks sal, I forgot about plumbing houses, dah,,, tri bros right in town,, thanks good luck
pat
here's the link
01-25-2003 23:18:49
Link
Jeff Hoo
01-25-2003 17:39:28
I'm going steel frame all the way on mine to get higher ceilings with wider spans. Doing it out of raw beams, not the typical pre-engineered type. (IOW, mine is "post"-engineered. Ha. Get it. I kill myself.
It's pretty easy construction (though I'm taking forever), you put flush plates in the slab/footing and then weld posts to that, then put rafters on that. Cut to fit and paint to match, as they say in the auto industry.
Theoretically it can be cheaper than wood, but then there are things that you can do with steel that you can't do (economically) with wood (i.e. taller ceilings and wider spans.)
kevin
01-25-2003 20:22:54
 Re: Re: OT Barn Construction in reply to Jeff Hoo, 01-25-2003 17:39:28
I've got a 24 x 36 pole barn. It has 2x6 between the poles which are 6x6. It is insulated and heated and looks just fine inside. I've sure appreciated that building during this exceptionally miserable winter.
