Anyone with a wiring diagram for a NAA ???
On the ranch in
01-26-2003 10:48:14
I like the forum ……good questions and good answers. My father is looking for a wiring diagram for his NAA. Any info on the wiring system any thing to help on my journey. IE: SPEC’S, LAYOUT, WIRE TYPE, READINGS etc. Thank you
Jim.UT
01-27-2003 13:06:46
 Re: Anyone with a wiring diagram for a NAA ??? in reply to On the ranch in B.C., 01-26-2003 10:48:14
third party image
The site that has been linked is great, but for some reason the 6V wiring diagram has not been working for quite awhile. Here is what it looks like.
J52J
01-26-2003 12:10:38
everything you need is on one site
Mike OH
01-26-2003 12:10:15
Check out this site. Should give you everything you need and then some. Good luck
Scott
01-26-2003 11:05:37
The harness is still available from New Holland (was Ford) and the Ford service manual has the diagram in it (same as 600 and 800 but without the lighting circuit) if someone has a scanner.
