Linch Pins
R.M. In AL.
01-26-2003 14:42:02
I have always used some stiff copper wire to hold my stablizer bar to the other pull bar when its not hooked up to an implement.I finally broke down and bought me 2 linchpins with the little piece of chain and a large carter key on the end and the round springloaded ring pin on the hookup end.I can't figure how this thing is suppose to work to hold both bars togather when its not hitched up to an implement.Does anyone have a good picture of that.I may be missing a part..Thanks R.M. In AL.
raytasch
01-26-2003 14:52:45
 Re: Linch Pins in reply to R.M. In AL., 01-26-2003 14:42:02
I've been using a piece of old inner tube, heavy as from a tractor. Cut a piece about 6"--8" square or round, doen't matter, and put a 1" hole in the center of it. Slide it over your lift arm and stabilizer and it will hold them together. Cut a couple extras and slip them over the leveling box arm and then when the original rubber pieces go bad in about five years you have a replacement. Believe me, these things work good and they are cheap.
fwiw,
ray
R.M. In AL
01-26-2003 21:34:04
 Re: Re: Linch Pins in reply to raytasch, 01-26-2003 14:52:45
Thanks Raytasch: I bet a piece of old bicycle tube would work good also.I have a bunch of those things left here by the grandchildren.I bought those old linch pins but don't think thats what I want.Thanks again hope your staying warm..Its finnally warming up here after about a week of very cold weather....R.M. In AL.
