Rodney..... ....sometimes you just can't rebuild an engine without a micrometer, ok? Rotating valve.....some exhaust valves have "automatic" rotators to prevent burned exhaust valves, this is a good option to install if your early engine doesn't have them already installed, later engines had them. Width of oilpump gear, measure it. so you can specifiy...or...bite the bullet, and buy a late N-oilpump. 3/4 is better. Sleeve wall thickness.....important if you are replacing the cylinder sleeves because castiron sleeves won't fit innna block bored for steel sleeves. And steel sleeves won't "lock" innna block bored out for castiron sleeves. My opinion, castiron sleeves are better seals to piston rings, higher compression for more power and longer wear. Worth the extra cost to have the early block bored out for later castiron sleeves. Bearing sizes are base upon the difference from the original standard crankshaft mainbearing journal size 2.248-2.249 and the current mainbearing journal size. The original standard rodbearing crankshaft journal size 2.0935-2.0945. These are 4-point measurements taken with 1/10000 capable micrometers. Plasti-gage is use to determine the currrent bearing clearance but doesn't really tell you what the journal size is. Usually there is etched on backside of bearing shell its mfgr size. Engines after s/n 8N433578 had diamond to indicate that the block came from factory with castiron cylinder sleeves. Many blocks have been bored out to fit the better castiron sleeve so the diamond is not a "sure thing". Look at the blocktop under strong light and maybe magnifier glass, castiron sleeve will look almost 1/8 thick, steel sleeve will look less than 1/16 thick. Both castiron and steel sleeve engines used the same piston diameter. Modern metalurgy 3-ring pistons are better than 4-ring pistons. All this information is readily available in the highly recommended I&T FO-4 manual. $29 cheap, gettcha 1 and readitt..... ...respectfully, Dell
