3 Pt Hitch Receiver
Pat Williams
01-27-2003 18:41:08
Several months ago someone posted a picture of an adapter that attached to their 3 point that would allow the use of a 2 inch receiver. The picture had all the measurements on it. I searched the archives and could not find it - could someone please re-post it or email it to me. Thanks!
WARNING!!!!!!!!about hitch receiver use.......
01-28-2003 07:01:45
 Re: 3 Pt Hitch Receiver in reply to Pat Williams, 01-27-2003 18:41:08
Remember your three point does NOT have down pressure, so when you have negative tongue weight your hitch will rise, unless you have some way to prevent vertical motion.There are stay bars that go between your top link mount and your lower arms to hold the hitch at a preset level, but then you lose your easy hookup ability. So.....don't go around with the weight on the trailer at the back, and watch out when trying to load stuff with ramps. Truck
Pat Williams
01-28-2003 07:39:54
 Re: Re: 3 Pt Hitch Receiver in reply to WARNING!!!!!!!!about hitch receiver use......., 01-28-2003 07:01:45
Good point - I mainly need something to be able to quickly move around a couple of car trailers (unloaded), a boat, and a camper. Gets to be a big pain backing the truck up to everything all the time. Thanks for the info.
Pat Williams
01-28-2003 04:49:17
Thanks Guys! Thats exactly what I was looking for.
Ed Gooding (VA)
01-28-2003 04:39:32
Hi Pat. Here's 3 pics of mine, with dimensions noted:
Third Party Image
Third Party Image
Third Party Image
Hope this helps..... ..... Ed
'52 8N475798
Another option for a 2 receiver, Philip
01-28-2003 04:33:28
third party image
Pat, here is another version of the 2" receiver hitch on an N tractor. It cannot be raised and lowered like Mark's, but it may be more stable and easier for a novice welder like myself to build. The only purchased part was a truck bumper 2" receiver adapter. The rest is scrap steel to bolt to the 11 hole utility bar. Philip.
Willy-N Here it is Picture of it
01-27-2003 19:30:52
third party image
I made this one for my Massey 135 works great easy to build 27 inches wide and 27 inches high. Made of box steel and a section of a reciver hitch welded on some strap steel with pins for the Lower Link Arms to hook to. Mark H.
Bill 52 8n
01-28-2003 09:12:06
 Re: Re: 3 Pt Hitch Receiver in reply to Willy-N Here it is Picture of it, 01-27-2003 19:30:52
I like the chain hooks welded on the corners, look like they would come in handy.
Bill
Willy-N
01-28-2003 09:53:47
 Re: Re: Re: 3 Pt Hitch Receiver in reply to Bill 52 8n, 01-28-2003 09:12:06
Allows me to pull from both sides of the lower link assembly at the same time and keep them low as not to pull the front end up and over if the load snags something. Mark H.
