Noisy rearend
Phil - AL
02-06-2003 12:50:13
Only after eating chille with lots of beans - Oh, I mean my 2N.
Drove the 2N for the first time last night and the rearend is noisy in all gears. Is this something I should worry about or let it go. The tractor will see light duty.
BOB
02-06-2003 19:00:39
 Re: Noisy rearend in reply to Phil - AL, 02-06-2003 12:50:13
PHIL if you drain trans oil out,i would pull PTO shaft and have a look at your ring gear with mirror. mine was noisey for 5 years but then she had enough BOB
raytasch
02-06-2003 16:05:21
I would bet the noise will not cure itself or get any less. First thing I would do is get it hot and drain the rear end tranny oil. Probe around in the oil with a magnet; you're looking for iron particles. First guess would be pinion.
ray
