Order Ford 8N Parts Online
48 8n oil leak and missfire
Andy
02-06-2003 18:51:10
I was out playing with my 8n looking for the source of a couple of leaks and discovered some other not good stuff. First the leaks. I have one that looks fairly easy to fix on the governor, appears to be just a bad gasket. The other one is on the oil pan on the left side in the front. The bolts are pretty snug so I think it is a blown gasket. How difficult is the oil pan gasket to replace? I was planing on removing th front axle for new bushings anyway so it will already be off, and if I understand the manual I don't have to split the tractor to do it. Now the bad stuff. I had been suspecting a bad spark plug for a while. I pulled them to clean them and still had the miss. I then pulled the wires off individualy,and found the #3 and #4 wires cand be off with no change in engine performance. Not good. plenty of spark with a grounded plug though. I don't have a screw in type compression tester, but will get one before the weekend, so no compression test results. So my plan is to do the wet/dry test first. If I have little to no compression on the two adjoining cylinders would my prime suspect be a blown head gasket? If not and I am lookig for sticking valves do I check that with the head off or is that done with the valve cover off the side of the engine? Thanks, Andy
Mountainman
02-07-2003 09:56:12
 Re: 48 8n oil leak and missfire in reply to Andy, 02-06-2003 18:51:10
Andy,
Be Careful! That pan is heavy!
I've seen postings here that you can check for valves sticking by looking through the side covers. Makes sense to me. You can also free a sticking valve sometimes by soaking it with MMO through the side openings.
Definitely do the compression tests. But I would replace the spark plugs too unless they are real new - old plugs sometimes fire fine until they are under load.
hth
Mountainman...CA
DC
02-06-2003 19:56:26
with the front end already off the oil pan comes off very easy (mine did anyway)just take out bolts and I used a paint scraper to get it started then a screwdriver to help it and it came off very easy
Andy
02-06-2003 19:29:46
Just went out to check and is wired corectly. Ireversed 3 and 4 just for grins but no change.
Dave Smith
02-06-2003 19:05:04
Are you sure the wireing is correct on the distributer? The fireing order is 1 2 4 3 counter clock wise. #1 is top left. Try changing the two wires and see what you get.
Dave <*)))><
