Order Ford 8N Parts Online
8n electrical cont'
Aaron
02-12-2003 13:15:28
I had the question about how many volts should go to the coil from the resistor. A lot of people answered and now I have to ask if the 4+ volts to the coil is when the motor is turning over or when the key switch is on? when it is just sitting there we have 6 but when we turn it over it jumps considerally lower. Thanks again
Dell (WA)
02-12-2003 13:45:36
 Re: 8n electrical cont' in reply to Aaron, 02-12-2003 13:15:28
Aaron..... .....a good OEM 6 volt frontmount ignition coil should read about 3.5 volts (4 max, 2.5 min) at the coil terminal with the points closed and battery volts with the points open. (engine off) to close the points, put the tractor in gear and push on the rear tire until points close. You can't get a good reading with the engine turning..... ....Dell
aaron
02-12-2003 14:41:38
 Re: Re: 8n electrical cont' in reply to Dell (WA), 02-12-2003 13:45:36
Thanks for the info dell, I think I am going to put a new wiring harness on it and start over because the resitor is showing 6 volts on each side. I dont know for sure if the wires are hooked up properly so I am going to do it. if anyone has additional info it would be appreciated thanks
MikeC
02-12-2003 18:09:14
 Re: Re: Re: 8n electrical cont' in reply to aaron, 02-12-2003 14:41:38
I don't know if you need it or not, but here is a link to the wiring diagrams on nseries.com's page. If you are gonna rewire they might be helpful.
Danny in CO
02-12-2003 15:12:39
Aaron,
If the points are open you will get 6 volts on both sides of the resistor. If resistor is bad, no volts will go through. For the resistor to go bad, it will burn into. If your wiring is bad, then by all means replace it. If the wiring looks good, do some other checking before replacing.
My $.02 worth,
Danny
