Order Ford 8N Parts Online
8n wiring cont again
aaron
02-12-2003 17:06:48
I replaced the wire harness and got everything hooked up properly, turned the switch on and the resistor started to smoke. I did get to check the resistor before it started smoking and I did get the desired 3.5 volts headed to the coil with the points closed. My question is could the switch be bad?
roger '40 9n
02-12-2003 17:19:50
 Re: 8n wiring cont again in reply to aaron, 02-12-2003 17:06:48
It is normal for the balast resister to smoke.
It runs hot and when it is first used
the factory oil coating burns off.
It is not a problem with your switch.
Roger in Michigan (Brrr)
aaron
02-12-2003 17:27:51
 Re: Re: 8n wiring cont again in reply to roger '40 9n, 02-12-2003 17:19:50
Thanks Roger and yes I am in northern ohio and Brrr is correct.
aaron
02-12-2003 19:07:25
 Re: Re: Re: 8n wiring cont again in reply to aaron, 02-12-2003 17:27:51
Thanks to everyone who responded to this thread and the other two. After reading everything I finally got it running tonight. Thanks again it saved lots of headaches
