6 volt regulator contacts
RayV
02-14-2003 13:11:02
My tractor is a 1953 TO-30. I think the 6 volt regulator is the same. The generator stops charging, if I tap on the regulator, it will charge for 10 seconds or so then stop again. This regulator is 1 year old, it has failed the same way as my last regulator when it was 3 years old. I can open it up, polish the relay connections, and it will be ok for a month or so. Any ideas? Just getting tired of cleaning contacts.
Dan in AZ
02-15-2003 19:14:33
 Re: 6 volt regulator contacts in reply to RayV, 02-14-2003 13:11:02
You could try one of these solid state type of voltage regulators. I have not tried them but they should be better than the point type of regulator. Maybe my 8N will get a new one soon, as the fairly new regulator works only when it wants to. They cost about $40.00 plus shipping.
Dan in AZ
02-15-2003 19:18:35
 Re: Re: 6 volt regulator contacts in reply to Dan in AZ, 02-15-2003 19:14:33
i'll try the URL link again. The web site is www.jimcotest.com
RoN of ohio
02-15-2003 15:03:57
You didn't say if your battery was dead or not. If your battery is charged enough to start the motor, then the regulator is doing its job. As I understand them, they prevent damage to the battery and generator by cutting out when the battery is fully charged. Just my opinion..Ron
Dan
02-14-2003 14:46:00
I would start with a very good visual inspection. Look at all wires for bare spots, tug on all connections... you may have some other problem ... I loose wire elsewhere in the harness could be causing arcing inside the regulator...
Then measure the battery voltage, it should be around 7 to 8 volts when it the tractor is running.
If that does not turn something up I would take the regulator and the generator to a good rebuilder and have them tested together.
Dan
