Order Ford 9N Parts Online
Going to look an 9N any advice on what to look for
rod
02-16-2003 06:29:14
Hi all I am going tomorrow to look at a 1949 9N that is what seller called it anyway. Are there any particular things to watch for with this model the sellers have upgraded to a bigger machine. Are there any real bad things to watch for that are expensive to fix? any advice appreciated.
regards
rod
9N oil in radiator
02-17-2003 13:01:58
 Re: going to look an 9N any advice on what to look for in reply to rod, 02-16-2003 06:29:14
went to look at this sad machine it had lots of oil in radiator does this mean cracked block?
regards
rod
John IA.
02-17-2003 17:37:42
 Re: Re: going to look an 9N any advice on what to look for in reply to 9N oil in radiator, 02-17-2003 13:01:58
Rod, not nessasarily, it probably a seaping head gasket or a cracked head. I've seen it twice and both times it was a cracked head. John
John IA
02-16-2003 17:50:14
Rod, bj/8n/mt usally gives good advice, and has refered you to a good site for info. The first thing you should learn from this site, is there's no such thing as 1949 9n. If the tractor is a 1949 it is a 8n. With that said good luck with your N purchase. John
How much do you want to know?==bj/8n/mt
02-16-2003 07:33:30
Below is a link to John Smith's most excellent n series page. The information there under buying an 8n pretty well covers it. Two n specific things I would look at are: steering play--expensive fix; and rear drum play on axels--also an expensive fix. Otherwise look at what you would look at buying a used car.
Your mileage may vary
