Oil lines
roger
02-17-2003 05:09:42
question, is it best to use stainless or copper external oil lines.thanks in advance.roger
Dell (WA)
02-17-2003 10:42:37
 Re: oil lines in reply to roger , 02-17-2003 05:09:42
Roger..... ..did you know that they still sell the external oil filter lines for your N-Tractor? they are all ready bent to fit..... ...Dell
Richard(WY)
02-17-2003 21:55:57
 Re: Re: oil lines in reply to Dell (WA), 02-17-2003 10:42:37
Dell, who sells these lines?
Richard(WY)
02-18-2003 05:05:42
 Re: Re: Re: Re: oil lines in reply to Dell (WA), 02-18-2003 00:32:03
Thanks a lot Dell.
cannonball
02-17-2003 07:52:08
I use steel brake lines from the auto store. Threads on fittings are compatible. I installed a spin on filter using the brake lines, and all is fine. Just need to check the appropriate length. On my project I had to shorten one line, and I used the same flaring tool I use on copper lines. It's a little harder, and I don't think you can get as much flare with the steel as you do the copper, but it's enough-- I've had no problems after about 4 years.
Richard(WY)
02-17-2003 05:15:13
They are steel lines.
Les, TN
02-17-2003 06:29:11
 Re: Re: oil lines in reply to Richard(WY), 02-17-2003 05:15:13
Since they only carry a maximum of 50 (or so) PSI, in theory you could use either. However, the OEM steel will tolerate a lot more abuse from bumps and bruises likely to be encountered on a tractor. Get the OEM replacements.
