Broken stud
roger
02-18-2003 15:15:37
broke stud that holds side cover on.would a #8grade bolt be just as good? or are these studs still avaliable? thanks in advance. roger
TomNy
02-18-2003 17:28:55
 Re: broken stud in reply to roger , 02-18-2003 15:15:37
Are you talking about the about the Screw assemble (stud with center collar and a wing nut) that holds down the air intake door over the air funnel. If so I have also been trying to locate one and have only been able to locate it with the door. I'm going to have a machine shop make one.
uh . . . Dell (WA)
02-18-2003 17:10:38
Roger..... ..not certain what side cover you are refering to. But studs are readily available at most good automotive parts places. You just have to know its vital statistics, like nominal diameter ....ie....5/16 or 7/16 or.... and then you need to know the thread specs.....as in TPI (threads per inch) 32, 24, 18....etc....and since studs can have different thread sizes on both ends, you need to know about that. And lastly, you need to know how long the stud.
Unfortunately, I flunked mindreading, (just ask my ex-wife), and I can not assist you further..... ...respectfully, Dell
