To kenny--follow-up on wheel weights
Ron from IL
02-20-2003 07:25:51
Kenny,
In answer to your response yesterday to my question about cast concrete wheel weights--yes, I DO have chains, but the combination of 1/4" of ice under wind-packed snow still slid me around in the deeper areas. From what I've read from other posts, those who have the combination of chains AND rear weights seem to have little problem with slippage. Cast wheel weights are rare and expensive, and I'm not going to chance loading the wheels with calcium chloride. I just wondered if anyone had cast their own weights. I saw a set on a tractor for sale in the classifieds not long ago, but they went with the tractor.
Ron
DickTN
02-20-2003 11:57:16
 Re: To kenny--follow-up on wheel weights in reply to Ron from IL, 02-20-2003 07:25:51
I'd be a little concerned about making concrete wheel weights unless you can figure a way to totally encapsulate the concrete. Concrete is great in compression, but it does not stand up well to tension or vibration stresses. Might crack or break with the stresses of bouncing around that a tractor is going to impose on it. Have you considered filling the tires with a mix of propylene glycol antifreeze and water? This will be non-corrosive to your wheels, non-toxic to pets and other animals. Granted that it will not be as heavy as calcium, but the tire will hold about 23 gallons x about 8 pounds per gallon or about 168 pounds per side. Might be enough to help your traction. Good Luck. DickTN
Blake (TX)
02-20-2003 11:10:09
Here's the text of the post by Kevin in NB Canada on Jan 15,2002:
"I have made wheel weights for two 8's with concrete and it worked ok. Removed wheel and laid it down flat on the floor with the dish up. Cut and welded a section of 13 gal grease drum in the dish centre to form out the drum / axle. Welded 4 - 3/4 in ready rods that reach from the dish face to just above the rim level so that the poured concrete left enough rod showing to put on a nut and washer. Cleaned and painted all metal. Slathered grease on rim and laid in some poly plastic as a release sheet. Poured full of concrete with a couple of bolts dropped in to allow lift -out with a chain. You end up with a big concrete donut flush with the rim. This might not work too well with rims that are not turned deep dish to the inside. Others may have good comment to offer regarding paint or rebar and expected weight. I have forgotten the calc weight added. I liked the approach when a local old guy told me of it. The weight is cheap, and concealed from view so it doesn't look bad. Quite awkward to handle though when tire changing. Good luck on whatever your weight project turns up..."
Les, TN
02-20-2003 08:58:49
Yep, somebody posted a good description on how to make em. Fergit exactly how it went just now but something about taking your wheel off, laying it on the ground, covering it with Saran wrap (for a mold release) or some such, and pouring it full of concrete. Mounting bolts were cast into it too somehow????
Search the archives. You might find it.
