Order Ford 8N Parts Online
My 8N won't rev up
Andy
02-24-2003 04:55:05
My 51 8N just had the carb rebuilt. I adjusted it by the advice on this board and now it runs pretty good. The problem I have is that it will only idle down to about 800 RPM and tops at at 1800 RPM with the throttle wide open. My proofmeter works fine and the engine runs strong and smooth. Ant ideas as to how I can get a little more on the high end? Sometimes it just seems to bog down a little and it needs a little more go to get the job done. Thanks...
Salmoneye
02-24-2003 05:02:11
 Re: My 8N won't rev up in reply to Andy, 02-24-2003 04:55:05
Start her up, remove the governor to carb rod at the carb and see if you can rev it beyond 1800 by operating the throttle shaft by hand...If so...The problem is governor or linkage...
The idle adjust screw is on the throttle shaft near the same connection...
I think...
