Order Ford 8N Parts Online
8N Side Mount Distributor
Patrick (NJ)
02-26-2003 11:35:24
I've been working on the distributor on my late '50 side to fix a crack in the oiler mount and to replace points and condensor and general cleaning.
The end play on the shaft is about .030 - out of tolerance. Also, the guide pins on the advance weights have slots worn into them where they have rubbed against the guide on the shaft. The lobes look fine.
I probably need to replace the shaft and the advance mechanism. For $120 in parts, though, I thought I might try to repair them first.
Anyone ever tried to press out the guide pins on the advance weights and replace them? How about machining a new bushing and riveting it in place to bring the end play back into tolerance?
Suggestions appreciated!
David S.
02-26-2003 14:42:03
 Re: 8N Side Mount Distributor in reply to Patrick (NJ), 02-26-2003 11:35:24
Pat,
With all due respect, if you can't fix it yourself, or know a machinist that will do it for free (or nearly), bit the bullet and buy a new one. Considering the shop rate for most any machine shop, they will not even get started on rebuilding your old distributor for $120.
You won't believe how nice the engine will run when the distributor shaft runs true and the points open and close as they should.
After 50+ years, spring for the "gold". Your N deserves that new distributor.
Regards,
David
Patrick (NJ)
02-26-2003 17:10:05
 Re: Re: 8N Side Mount Distributor in reply to David S., 02-26-2003 14:42:03
Thanks David, but that was the point...I can fix it myself. I was just wondering whether anybody had tried and whether there were any special things to worry about.
There is also no substitute for experience...so I guess I'll try to fix it and get me some in the process.
Jerry L az
02-26-2003 16:29:44
I just whent thru that same thing after counting up the cost of all the parts and busted knuckles it was cheaper to buy a new one 185.00..... .jer
Mike
02-26-2003 14:08:22
Hi Pat,
It sounds like you could use the services of a talented machinist. Ask around your area and where you work to find one, you should be able to take the distributer to him and find out what can be done for it and approximately what it will cost to have it done.
If you can, get a hold of others he has worked for and find out how reliable he is. You don't want a guy that does a bang up job only to find out it'll take him 2 years to do it.
Good luck.
Mike
Patrick (NJ)
02-27-2003 07:10:38
 Re: Re: 8N Side Mount Distributor in reply to Mike, 02-26-2003 14:08:22
Thanks for the input. I am going to try and press out and replace the guide pins on the advance and also make an oversize bushing to tighten up the end play.
I may end up buying a new distributor, but I'm going to give this one he!! before I do it...
Thanks again,
Patrick
Dave Smith, That a boy
02-27-2003 13:16:05
 Re: Re: Re: 8N Side Mount Distributor in reply to Patrick (NJ), 02-27-2003 07:10:38
Dont let a dumb thing like a distributer whoop you. Just think how nice it will feel when you whoop it.
Dave <*)))><
P.S. Did you notice I said when and not if.
Let us know how you make out and what it took.
