Jubilee
RayOh
02-26-2003 15:37:38
I Looked At A Jubilee Today That Had A Total Rebuild.The Guy Had The Bills For The Engine,Transmission & New Hyd.Pump.The Price Isnt Bad But It Has One Problem.The Hydraulics Wont Work.I Picked The Drawbar Up & It Goes To The Ground When I Let Go Of It.Any Ideas Whats Wrong Thanks
Fessman
02-27-2003 16:37:01
 Re: Jubilee in reply to RayOh, 02-26-2003 15:37:38
Ray,
Mine looses prime all the time. I have to rev the engine to get it to go. Sometimes pointing it down hill works too.
Fessman
Dave Smith
02-27-2003 17:04:53
 Re: Re: Jubilee in reply to Fessman, 02-27-2003 16:37:01
If you are loosing prime all the time you must have a leak someplace. It could be external or internal but it would have to be someplace that air could get back in. I would check the suction line first.
Dave <*)))><
ZANE
02-27-2003 06:37:34
On the 53 and up Ford tractors there is a gadget named the unloading valve. It is hydraulically shifted by the movement of the control valve. The control valve does not actually move oil to the ram cylinder. The oil is directed to the ram cylinder by the position of the unloading valve.
If and when the unloading valve stops moving then the lift won't lift until the problem that is causing this condition is fixed.
A faulty back pressure valve can cause the unloading valve to stick.
The unloading valve can stick on it's own.
The unloading valve has an O ring that can become worn until it will not allow the valve to move.
The pump could have lost it's prime too. The piston pump must be bled by opening the front head plug in the pump and running the engine slowly until all air bubbles are gone from the escaping oil. Stop the engine, replace the plug and start the engine again to see if that fixes the problem. It can!
Craig
02-26-2003 21:38:35
Just be careful, if you hve to replace a bad hydraulic pump your looking at spending $250. to $500. It more than likley has the older vane style pump that is hard to find(in good working condition).. Craig..
Gary
02-26-2003 17:22:59
Leave the control lever in the DOWN position when priming pump. You want ZERO resistance to oil flow.
David - OR
02-26-2003 16:41:45
If the tractor is not running, and the touch control has previously been in the down position, then this is what should happen, regardless of the current position of the touch control.
If the touch control is in the down position, then this is what should happen, whether the tractor is running or not.
If the touch control is in the up position with the tractor running, and the 3 point lift won't raise, the most likely culprit is that the front hydraulic pump has lost prime. The easiest way to restore prime is to pressurize the transmission using shop air and a rubber-tipped air gun (while the tractor continues to run). The dipstick is a convenient place to apply such air. Don't over-do it -- 5 PSI (i.e. a quick shot of air) is usually enough.
RayOh
02-26-2003 17:59:12
 Re: Re: Jubilee in reply to David - OR, 02-26-2003 16:41:45
Thanks Guys.Just Might Go Get It Tommorrow.He Said The NH Dealer Didnt Know What Was Wrong With It & They Did The Work On It Last Fall.He Wants A 4 Wheel Drive JD So He Shouldnt Have A Jubilee Anyhow. Thanks
