Wheres the short?
Rich (swVA)
02-27-2003 06:35:37
The other day mt 8N quit running on me and when I tried to restart the ammeter showed a full negative needle when I turned the key on. I also noticed that the wires leading from the key switch were hot. I replaced the ignition switch thinking that was the problem. The tractor started and ran fine a couple of times, but now its giving me the full discharge indication again when I switch the key on.I am thinking the problem might be in the resistor block. Any one have any ideas on this???
Claus
02-27-2003 11:47:25
 Re: Wheres the short? in reply to Rich (swVA), 02-27-2003 06:35:37
This sounds like a classic stuck cutout relay in the voltage regulator. Disconnect the bat. lead from the vr and see if the short goes away. If it does, replacae the vr...
Happy Motoring
Claus
soundguy
02-27-2003 07:32:15
Without seeing it, it is hard to tell.
Start trouble shooting by working back from the load.. when you finally disconnec the shorted part, the ammeter will tell you... and then you repair / replace that part.
Soundguy
