Help with tire size confusion
Phil R (IL/MT)
02-27-2003 06:35:47
My N is in Montana and I am in Illinois. One web source says that the standard tire for a 8N is 10x28 but when I go to TireChains.com, they don't list at 10x28 but rather the 11.2x28. Please help me with my lack of knowledge here. It appears that my N has "regular" tires on it. I presume I want the 11.2x28 but what is the difference? Width of tire?? Do they make a 10x28...thanks
ed
02-28-2003 05:09:19
 Re: Help with tire size confusion in reply to Phil R (IL/MT), 02-27-2003 06:35:47
To see how tractor tires sizes are measured, go to our wed site & click on "How to Order & FAQ" them pull down to "How to Measure"
and==bj/8n/mt
02-27-2003 08:56:47
What 2 Fords Mike said. I have been told that the difference is where the width is measured. 10 28 at the rim; 11.2 at the tire's widest point.
When I got one of my 8n's it had 10 28 Firestones on the rear. Tore one up and gave up looking for a repro. Measured the one good 10 28 against new 11.2 Delta and the Delta was five inches bigger in circumference. Could have been wear; could have been different manufacturer; could just have been I measured on a Monday. Wound up buying a pair of 11.2's.
Unless you have some big need to do it today I would make sure what was on the tractor before I bought chains. Although you could probably take up five inches in circumference in the chains better to do it right and do it once.
Your mileage may vary
2fordsmike
02-27-2003 07:45:56
Yours is a common area of misunderstanding and misinformation. Yes, an 11.2x28 is almost an exact replacement for a 10x28. The name change took place way back in the mid- to late-1950s! Here are other sizes that fit Fords from the 40s-50s. 12.4x28 replaces 11x28, 13.6x28 repleaces 12-28, 14.9x28 replaces 13-28. Good luck. Mike-Iowa
