When did???
8N
02-27-2003 18:49:50
Ok this has been asked befor.. But what year did the 8N come out. I think my motor has been changed. The cast # on the block k126 tells me its a 46 model. Did Ford make a 8N in 1946 ?
Speaking of which . . . Les, TN
02-28-2003 06:59:42
 Re: When did??? in reply to 8N, 02-27-2003 18:49:50
That tractor I mentioned a few days ago with the cracked block (trying to sell for $2500—right!) did not have the casting number on the starter hump like mine does. Was that a later innovation or what???
TD
02-28-2003 05:54:53
Hey 8N-
Although the first 8N's were produced in July, 1947, they are considerd a 1948 model as Mike C showed. What about the serial number on the block? It would verify the casting code too and as Dell said the blocks were changed out. For parts, look in a Master Parts Manual and go by your model, year, and serial number.
Dell (WA)
02-27-2003 20:30:44
You do realize that ALL frontmount N-Engines from June 1939 to mid 1950 are directly interchangeable, don't you? First 8N's in June 1947. Late model sidemount 8N's are also interchangeable with early N's..... ...respectfully, Dell
Scott-NC
02-28-2003 14:10:25
 Re: Re: When did??? in reply to Dell (WA), 02-27-2003 20:30:44
My 2N has casting dates of July '47 on the axle trumpets and June '47 I believe on the block. Occassionally I find a smattering of red paint under the gray, but only on parts that were 2/9N specific like the brake pedals. Were the 2 and 8N's built side by side for a while in 1947?
Dell (WA)
02-28-2003 16:32:21
 Re: Re: Re: When did??? in reply to Scott-NC, 02-28-2003 14:10:25
Scott..... ....best guesses and empirical information alludeds that yes, 2N's & 8N's were built side-by-side for a while in 1947. Ford archives can neather confirm or deny that supposition. Or maybe the right question hasn't been asked to the right person..... ....Dell
Jim Cox
02-27-2003 20:06:50
you'll have to paint the motor gray. :-)
kidding
Jim
8n
02-27-2003 19:46:04
Thanks Mike C !!!!! ! But is there any cast numbers on the rear of the tractor housing anywhere I may find out the year they may be?
Don (NC)
02-28-2003 05:50:18
 Re: Re: When did??? in reply to 8n, 02-27-2003 19:46:04
See my response to the "My first tractor" post one page back.
Don (NC)
02-28-2003 05:50:04
MikeC
02-28-2003 03:36:30
Look around on the other castings and you will find date codes. Some are in a 5 18 47 format, others may be in a format such as E187. Post what you find and we'll help you determine what it is.
John Gardner
02-28-2003 11:06:26
 Re: Re: Re: When did??? in reply to MikeC, 02-28-2003 03:36:30
re when did ---I have a 48 ??? the serial # is star-8- 51057.I was told that would be a 48?? as far as the date be on other parts I think I saw one on the rear axel
MikeC
02-27-2003 19:20:09
9N-1939 to 1941
2N-1942 to 1947
8N-1948 to 1952
Hope this helps!
JimNC
02-27-2003 19:19:53
There were quite a few made in 47 also.
48
02-27-2003 18:53:41
SOUNDS like 2n motor changed
