Safety is another concern with patching up a rim on a tire as bit as the N runs. When the inner surface of the rim is badly damaged and weakened by rust it is dangerous to use just any patch to try to get a little more running out of the wheel rim. The rim can explode when the air is applied to it in inflating the bad rim. You would be amazed at the power stored in the pressure against the rims of wheels. They can let go and cut you head right off from the body. I attended a seminar on wheels when I was the master mechanic in a Georgia Pacific plywood mill here in Talladega and they showed us the results of what can happen when one of those big wheels lets go under extreme stress. The wheels in particular that we were learning about were on the big loaders that take a whole 90,000 pounds of logs off a truck etc and move it around the yard. They said that there could be as much as two million pounds of pressure per square inch pushing aginst the edges of the wheel rims when carrying this load and turning etc. Also about half that much pressure when just being inflated to the correct pressure. They were so kind as to show the picture of some body pieces laying around the area after one of these big wheels had exploded. I have actually seen a couple of truck wheels explode after being repaired and being re-inflated. I would say that a 1000X20 truck tire is about the same as a couple of sticks of dynamite when they explode. Just don't be in front of one. They hurt too. Needles to say ever since I have left the area when a big tractor wheel is being inflated. I would be in the next county when that rusted and poorly repaired wheel is inflated! Zane
