If for no other reason than convenience. These newer "green" machines usually power down to almost no current draw when inactive for some XX? (you generally set the time interval) time. The power supply (200-300 watts) are listed as max output that they will provide under full load at 12v (or 5v, or 3v—whatever the particular part needs). Input at 120v is quite a bit less (do the math). Most of the time they're kinda idling along. Most newer monitors will automatically power down to about 10 watts in a "monitoring" mode waiting for user activity (mouse, keyboard). You can also set your hard drive to power down after some period of time of innactivity. It used to be that drives were advertised to have so many hours between failures (MTBF). When that figure got up to 300,000 (35 years) or so makers quit that jazz. That doesn't mean they never fail (you'd be wise to keep current backups) but that's generally not much of an issue today. If yer gonna leave it plugged in it would be a good idea to use a UPS. Mine's a 1200 watt line interactive (no direct connection to the mains line). Everything that comes out the back is induced, smoothed, regulated, spike and surge free. Inside power generation is from 48v DC (4 12v batteries). Power on — power off? Not sure it really matters much anymore. Mine's on 24/7—for convenience. Les, TN
