800/600 grilles
rob 8N11071 KS
03-03-2003 13:51:34
Are the grills for the Ford 800 and 600 identical?
Jim.UT
03-03-2003 16:01:41
 Re: 800/600 grilles in reply to rob 8N11071 KS, 03-03-2003 13:51:34
As Burt said, they are the same. But while we're on the subject, you should know that the Jubilee/NAA grille is just a little different than the 600/800 grilles. The difference is the crank hole. NAA/Jubilee grille has a round crank hole and the 600/800 grille has an oval shaped hole. I'm sure an NAA grille would fit in a 600/800 but it wouldn't be "correct" from a restoration standpoint. Just in case you care about minutiae like that.
9n141
03-03-2003 15:15:43
YES. BURT.
