OIL PRESURE GAUGE FITTING SIZE?
BOB
03-03-2003 18:10:50
HELLO,puttin new gauge on tractor and need to know the size of fitting at gauge end? some body had soldered old fitting to make work. as always thanks for the help. BOB
Dell (WA)
03-03-2003 19:09:18
 Re: OIL PRESURE GAUGE FITTING SIZE? in reply to BOB, 03-03-2003 18:10:50
Bob..... ...you know you can get pre-bent oil gauge lines with fittings already on the line for $15 (cheap). Think about it, why do you think they klugged a fitting? Probably because the steel line cracked and leaked all over the place, squirting under 40 psi pressure. Buy a new line so you don't loose your engine from lack of oil pressure..... .....Dell
soundguy
03-04-2003 08:07:02
 Re: Re: OIL PRESURE GAUGE FITTING SIZE? in reply to Dell (WA), 03-03-2003 19:09:18
At least he didn't " get a mallet and pound the line flat, then wonder why he didn't show any pressure on the gauge! "
Remember that guy about 6 mos. ago...
SouNdguy
