Front Crank Bolt Size
Paul
03-05-2003 10:12:12
What is the diameter and thread type of the front crank pulley bolt on a late 8N? Thanks very much.
Paul
Dell (WA)
03-05-2003 11:20:38
 Re: Front Crank Bolt Size in reply to Paul, 03-05-2003 10:12:12
Paul..... .the N's crownhead crankshaft pulley bolt is 5/8-18 X 1"L 1-5/16 Hexhead. Torque 150 ft/lbs.
HINT: stuff a bunch of soft 1/4" clothesline rope down any sparkie hole. The crankshaft will turn and push the piston against the rope up against the cylinderhead. Works eather way, install or remove..... ...Dell
Paul
03-05-2003 14:26:49
 Re: Re: Front Crank Bolt Size in reply to Dell (WA), 03-05-2003 11:20:38
Dell, Thanks for the information, but by listing the "L" after the thread size, are you saying it's a left hand thread? I was hoping to pick up a replacement from a hardware store on the way home. Thanks in advance.
Paul
Blake(TX)
03-05-2003 14:46:17
 Re: Re: Re: Front Crank Bolt Size in reply to Paul, 03-05-2003 14:26:49
Paul,
It's right-hand threads. I have mine off doing a rebuild right now and I just went and looked at it to confirm.
Blake '52 8N512510
Rosharon, TX
Dave Smith
03-05-2003 15:17:24
 Re: Re: Re: Re: Front Crank Bolt Size in reply to Blake(TX), 03-05-2003 14:46:17
Nice Job on you're 8N site. And the warbirds site. Keep us informed of additions.
Dave <*)))><
Blake (TX)
03-05-2003 16:58:29
 Re: Re: Re: Re: Re: Front Crank Bolt Size in reply to Dave Smith, 03-05-2003 15:17:24
Thanks, Dave. I've been enjoying your rebuild pictures, too.
I finally decided that I needed to learn HTML last week. I found a good tutorial at htmlgoodies.com and started playing. The tractor site is both a place to share and a learning exercise.
I plan on adding a bunch to the Warbird section as soon as I find time, probably after this rebuild is done. I'm heavily involved as a volunteer and crew chief at LSFM and have accumulated alot of good pictures (and experiences) over the years.
Blake '52 8N512510
Rosharon, TX
Les, TN
03-05-2003 11:37:48
Unless I've just got an odd bolt, mine takes a 1-3/8 wrench. You can getcha one (the wrench) at TSC for about $6.50.
Dell (WA)
03-05-2003 11:59:13
 Re: Re: Re: Front Crank Bolt Size in reply to Les, TN, 03-05-2003 11:37:48
Les..... ..1-3/8 is 1.375 last time I looked. I just miked my 52 8N's frontcrankshaft crownhead bolt at 1.310, 1.315, 1.325 and my 1-5/16 socket fits just fine, thankyou.
Yes, you can probably use a 1-3/8 6-point socket wrench just fine. 1-5/16 is not a common size that is why I mention it..... .....respectfully, Dell
Dan (Myersville)
03-05-2003 12:14:01
 Re: Re: Re: Re: Front Crank Bolt Size in reply to Dell (WA), 03-05-2003 11:59:13
And if you are replacing the bolt with "standard" 5/8-18 hardware the headsize will be 15/16".
Huh . . . Les, TN
03-06-2003 07:36:58
 Re: Re: Re: Re: Re: Front Crank Bolt Size in reply to Dan (Myersville), 03-05-2003 12:14:01
I couldn't get a 1-5/16 to fit so got a 1-3/8 12 point box-end wrench which fits perfectly. It's a cheapo "China" wrench (about $6.50 from TSC) but it fits. The 1-1/4 socket hardly goes over the crown part; 1-5/16 does that nicely, but won't fit over the hex. I don't have a 2" mic but laying a scale on it looks like 1.375 across the flats.
Maybe something got changed somewhere along the way.
