Order Ford 9N Parts Online
9N 6 volt battery
Patrick
12-28-2000 05:51:40
Just a quick dumb question....
I got a 9n tractor without a battery - 6 volt system. I bought a new 6 volt battery and put it in. I connected the negative to ground. And it started the first couple of times - but the amp meter kept reading negative. Now the battery is dead after 2-3 starts. Are the 9N - 6 volt systems positively grounded. If anyone could help, that would be great. I have the battery in the spot if you wear sitting down on the seat - positive would be to the right-front, negitive to the left-rear. Thanks...
bg
12-28-2000 06:14:48
 Re: 9N 6 volt battery in reply to Patrick, 12-28-2000 05:51:40
The battery doesn't care if it is positive or negative ground. The generator will have to polarized to whichever ground you use. The cutout probably is the culprit. If it malfunctions, it can let the battery discharge back through the generator.
Old George
12-28-2000 06:00:25
Patrick, the 6 volt system is positive ground. That is why your ampmeter indicated discharge. I will a include a link to wiring diagram below. You will have to charge your batt. Hope this helps.
Alan Esch
45 2N 183513
Patrick
12-28-2000 06:03:17
 Re: Re: 9N 6 volt battery in reply to Old George, 12-28-2000 06:00:25
Thanks!!!!
Phil (NJ)
12-28-2000 14:23:03
 Re: Re: Re: Re: 9N 6 volt battery in reply to Snowplow, 12-28-2000 10:39:05
add:#5
Polorize the GEN "before" starting OR you will
toast your new cutout.
(It polorized the first time the cutout closed when you had it _ve ground and welded the Contacts)
JMHO
Snowplow
12-30-2000 18:40:45
 Re: Re: Re: Re: Re: 9N 6 volt battery in reply to Phil (NJ), 12-28-2000 14:23:03
Good point!
