Perry..... ...the problem with N-Carburators is they are out in the open where everyone can get their screwdrivers on the adjustment jets. One of the founding members of this great N-Board used to claim that 80% of all carburator problems was found in the ignition system. Something to think about. Meanwhile, that still doesn't get you started wit a mis-adjusted carburator. This is what I'd do. Set both jet adjusts to 1 turn out. About 1/2 throttle, whiff of eather, and get it running. After warmed up, throttle down to about idle, and adjust idle mixture for max RPM's. Throttle down as slow as you dare and max idle mixture again. Then set idle speed to 400-450 or even 500, what ever makes you confortable. Then max idle mixture again. Main jet/power jet. usually set under load, like plowing or going up a really steep hill, turn out 1/8 turn at a time until it takes the throttle smoothly. Then check your sparkplugs. Are they black and sootie (too rich), clean an white, (to lean), light tan/grey just about right. If you turn eather jet more than 2 full turns, you are probably mis-adjusted or got other problems..... ....Dell
