Order Ford 8N Parts Online
8n Year ?
Rob JW
03-09-2003 21:56:14
Thanx for your help, I have just purchased a 8n, but am not able to make out the sn# on the motor.On the rear axle housing the only number that is clear is 8n 4013 A2. Does that help or not ? Distributor in front. Came with rear blade,chains, & MF hydraulic loader bucket for $2000.00 cdn. Runs very good, is that a reasonable price? Thanx in advance for your help.
Ken N Tx
03-10-2003 13:36:18
 Re: 8n Year ? in reply to Rob JW , 03-09-2003 21:56:14
Check out this website for more info.....
John G al.
03-10-2003 07:09:16
 Re: Re: 8n Year ? in reply to Dell (WA), 03-09-2003 23:51:13
I'll tell you a little trick on how to get the # to become visable. sand the flat spot where the # is (100) grit will do then wipe clean . Now get a # 2 pencel and rub in till you cove the area well, then with your finger just gently wipe it off !!! and there it is. any way it has worked for more than once. you should see a star or a diamond , they indicate what type of sleeve is in the piston.. 8*57568get the idea??hope this helps
