Order Ford 8N Parts Online
Im an 8N neophyte
rick craig
03-10-2003 16:44:44
there's a lever right below the seat, in front of the rear axle housing. what in the world is this for? also by the gear shift there's a switch that looks like a light dimmer switch is this what it is? after you get through laughing at me please feel free to answer my question before i hit the ejection button and fling myself into the front yard. thanks. be safe. rick(the 8N neophyte)craig
James
03-10-2003 19:16:51
 Re: im an 8N neophyte in reply to rick craig, 03-10-2003 16:44:44
So then you mean that lever blow the seat is NOT the Muffelur Belt Tensioning Lever? That darn guy at the parts house musta just been trying to sell me another part! hehehe....
Bill 52 8n
03-10-2003 19:47:51
 Re: Re: im an 8N neophyte in reply to James, 03-10-2003 19:16:51
James you got it all wrong, the lil lever pops the lid so you can top off your headlight fluid when its low.
Bill
yer both wrong . . . Dell (WA)
03-10-2003 21:01:38
 Re: Re: Re: im an 8N neophyte in reply to Bill 52 8n, 03-10-2003 19:47:51
the little lever under the 8N seat is for "FLUSH" (grin)
John A - Va
03-10-2003 17:32:33
The little lever under the seat, position it so it's pointing up, and unless you are doing a lot of plowing, forget about it. The dimmer switch looking thing, is the starter buton. As Dave has said, for safety reasons, it's supposed to be so that you can only start the tractor in neutral.
Happy 'N'ing,
JA
Dave Smith
03-10-2003 16:59:37
Rick, On a 8N that little lever is the Draft, position controll lever. The 9N and 2N does not have it.
The button that looks like a old fashoned dimmer switch is the starter button that is connected to a safety interlock in the transmission. It's purpose is to stop the tractor from starting in gear. If it has been bypassed, get it fixed. That is a important safety feature.
Dave <*)))><
SteveB(wi)
03-10-2003 19:14:08
 Re: Re: im an 8N neophyte in reply to Dave Smith, 03-10-2003 16:59:37
Pretty much the ONLY safety feature. Must have been fewer lawyers in that era.
Ron (8n509270)
03-10-2003 16:57:53
The lever under the seat is for draft control or something or another. Mine don't work so I am not sure.
The button next to the shifter is suppose to be the push button start.
