At the voltages needed to fire spark plugs, "rubber" tires are actually a fairly good conductor. If you don't believe this, pull a plug wire off a spark plug, and hold it next to, but not touching, the front tire. (You can extend the plug wire with a chunk of Romex as needed for this demonstration). An N ignition system in good condition can draw a 1/4 inch plus stream of sparks to the tire. Cars are relatively safe in thunderstorms not because the "rubber" tires are insulated, but because the car and its tires form a grounded Faraday cage around the occupants. Most rubber/plastic/vinyl products used in automotive service contain additives such as carbon black to enhance resistance to sunlight and chemicals. These additives make the material more conductive than the pure base substance would have been. The hoses for the intake tube would be good candidates for such additives, given their proximity to gasoline. Assuming that you see the sparks only with the tractor running, and assuming that there are no bare 6 volt wires shorted to the intake pipe up under the hood, I suspect what is happening is the intake pipe is providing an alternate ground return for the spark plug voltage back through the air cleaner and the sheet metal of the hood and thence to the battery/coil. Perhaps your battery ground strap needs to be cleaned up, or one of your plug wires has an intermittant short to the block. You can confirm the source of the sparks by shutting the engine off, then turning the key back on (but not starting the engine), and wiggling the intake pipe. If there are sparks now, the intake pipe is in contact with 6volts somewhere. If there are not, the sparks are related to firing the plugs.
