Mechanical advise please !!!!!!
RJ
03-11-2003 18:41:00
8n has new distributor, new points,new plugs, was running fine,tried to start,engine would turn over,but she would'nt start !!Pulled the hose off from airfilter to carb,gas poured out of carb,flooded right ? checked the plugs and they are bone dry.Could the carb floats be stuck ? any info or suggestions greatly appreciated.
tooly
03-11-2003 21:44:34
 Re: Mechanical advise please !!!!!! in reply to RJ, 03-11-2003 18:41:00
Lots of times the float wont hold the fuel back because of dirt under the needle. I found its always worth a try to shut the fuel of at the tank and take the drain plug out of the bottom of the carb. when fuel stops running out , replace the plug and turn on the gas. with the float down and the needle wide open,the rush of gas will wash out the dirt the float needle will shut off.Hope this helps.
Joel (So Cal '44's)
03-11-2003 18:44:53
Floats may be stuck. Had that happen a couple weeks ago. After I fixed it... I shook the cab to HEAR the floats rattle around. Let's ya know that they're not binding.
Joel
